mkgrady
- Massachusetts
I hope to install a generator interlock kit on an old Sylvania Panel. It is a 200 amp 30-40 installed in 1978. It's in good condition. Cat #ALB2030-40. The problem I see is the main breaker is in the upper section of the panel and is ON in the down position. I have not seen this before and I am wondering if I can get an interlock kit for this setup. All others I have installed had the MCB ON in the up position. I can't tell without taking it apart but it looks the MCB can be unbolted and flipped over so that up is ON. Has anybody run into this issue and come up with a solution?
