LCELECTRIC
- Los Angeles, California
I am installing a 225A 3PH sub-panel that will be re-using the existing bottom fed sub-feeds and the panel I am using says it can be inverted for bottom fed applications...I am a little confused though as the circuit numbers are stamped into the cover so instead of circuit 1 being on the top left and circuit 42 being on the bottom right, circuit 1 is now on the bottom right and circuit 42 is now on the top left...How should the breakers be installed? Do I still start with circuit 1 on the top left or the bottom right? My panel schedules on my plans do not specify an inverted panel. Any suggestions would be greatly appreciated!
