Hal Sullivan
New member
If the UPS is 208 VAC input and output with an Isolated Ground required by the electrical engineer or customer how is this wired? There is no UPS manufacturer, to my knowledge, that provides a five wire static switch so if you have to go to the static bypass or maintenance bypass that you can pass the I.G. ground upstream to the seperately derived source where you should be tying the IG to the XO.
