joshfromoshoto
- Wyoming
- Electrician
I cant seem to get a straight answer on this. Will a fuse protect what is upstream from it? I have a customer who had a splice burn up in the power companies utility box. The service drops from a pole, hits a splice and then runs to a set of 200a CTs, and from there into a 400a main fused disconnect. On the night that the splice burned up, the power company said that he pulled over 600a all night on the leg that burned up, and blamed his fuses, saying that they were faulty. My understanding is that while the splice was burning, it was pulling excess current, and since its upstream from the fuses, that they would not blow, as nothing on the load side was pulling that much current and that the splice was solely to blame. When I questioned the accuracy of the CTs that arent rated for the service, they said that its worked fine and never had issues before. I will also add that there are no signs of excess current or heat anywhere at all, aside from the splice.
