urd question
It should also be noted that URD cannot be exposed to sunlight if it's not dual rated. For instance, it cannot be used for an underground service where it emerges from grade at a poco pole at the other end and connects to an overhead drop. It's only for use from meter socket to transformer pad and nothing else. If it's dual rated, then it has much broader usage.
