Hendrix
- New England
What danger does URD pose if it enters a building?
If I understand your question correctly, I see two factors:What danger does URD pose if it enters a building?
overload short of a bolted fault .
I was thinking of a rubbed or damaged insulation type fault within the cable. It could be high enough resistance (because of small surface area) that it could carry a substantial overload and generate lots of local heat, but not necessarily enough to trip protection on the POCO side.Gold....what is that?
Once the service wiring has reached the service disconnect, which must contain OCPD,
