Use 12-3 or 10-3 instead of 12-2?
pghsebring
New member
Is there anything (code-wise) preventing the use of 12-3 or 10-3 instead of 12-2, for a SA circuit in the kitchen, even if you're not going to use one of the conductors? Could you just "cap" the extra conductor, how would you go about doing this? Cut it short, then wire nut?
Last question: any problems running a 12-3 or 10-3 to a receptacle for a dishwasher, fridge, or range hood, and sharing the neutral? They do not need to be GFCI, correct?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
I am closing this thread, in accordance with the Forum?s rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. Although your member profile shows that you may be a member of this industry or of a related industry, it is clear that you are not an electrician. But your question makes me concerned that you are planning to perform electrical work at your own home. We are not permitted to provide ?how-to? assistance to a ?do-it-yourself? person.
If I have misinterpreted the situation, if this is a design task that you are performing on behalf of your employer, then send me Private Message to explain the circumstances. I would gladly reopen the thread, and post an apology for the delay and the inconvenience.
