Is there a good reason for using the 1.154 multiplier with 208 volt single phase loads when other three phase loads are connected to a three phase wye 208/120 transformer. Example: 8 amp motor load
(8 X 1.154 X 208) = 1920 vA instead of 8 X 208 = 1664 vA.
If this single phase line to line load was applied to a three phase transformer and there was no other load, it is conceivable that the transformer will see the load more appropriately as 1920 vA which is an increase of 256 vA.
Having said that, why would you use this multiplier ( 2/3 of square root of 3) in calculating a list of about 10 items where only one or two of the loads was single phase line to line load.
Can someone please set me straight on this one.
Also where is Rattus? Unable to make contact!!
