I am a new forum member. I am a fireman, not an electrician. I have strong general knowledge of electricity, but certainaly, I have had no formal training. Recently, I have become involved in a discussion in a model railroading forum about grounding control systems. Living in suburban Chicago my whole life, the use of EMT has been the standard in buildings around me. I know Romex and other stuff exist, and I am familiar with it and its uses, but not around here...The power sources we use for model railroading are commonly 120 VAC input and 15 VAC, 5A output which is connected to a Digitrax brand Command Station/Digital Signal Booster which issues track power and control signals to the trains. I asked if connecting the ground terminal of the control device to the screw that holds the outlet cover on serves to ground the system. Was told to connect it to the green wire. Replied that (of Course) "I don't have a green wire-only have conduit." Oh my God! What a discussion I have created in the Model railroad forum! It seems like no one has even heard of Cconduit (EMT)! Replies have almost entirely been of the flavor of "I have never heard of an entire home being wired with conduit, but maybe you are referring to that armored BX flex cable that used to be used extensively in house wiring. That type of cable has an uninsulated ground wire running through it that provides the continuous ground required by code.
However, taking what you said at face value, your home is probably not in conformance with the current National Electrical Code as far as
grounding practices are concerned."
So, I'm turning to those who should be able to educate me! What's up with conduit and why is it so foreign to so many? Seems like everyone thinks my house is a death trap!! Of course, I know it isn't, but as weird as they think I am, I guess I think they're weird for NOT using conduit!
Thanks to all in advance!
Your Friend,
John Lardino
Woodstock, IL
Your Friend,
John Lardino
Woodstock, IL
