Are there any thoughts about expanded copper being used as a power supply in electrical appliances that use 110VAC per NEC? Expanded copper is a solid sheet which is run through an expander so the integrity of the material is good and the strands can be calculated for resistance based on size (and some other factors). Any thoughts on this? This devices would be similar to a circuit board except expanded copper instead of the sheet. Naturally a change in ressitance over the solid copper sheet would be needed.
Thanks
Thanks
