I need to find out if the use of British wiring cable is accepted in the US. We purchase equipment from a UK manufacturer that requires a 3-phase 208-240VAC input. Their equipment has a 32A/phase breaker supplied at the rear. The wiring they provide is only labeled BS 6007 which is a British Standard. The manufacturer claims that the wiring is BS6007, 4 core 4sq.mm EPR
(rubber) insulated. It has a current rating of 34 amps, continuous. Each phase wire appears to have a physical diameter of 12AWG wiring, making it appear to be too small in my mind. The equipment draws about 22A per phase. My concern is that if I supply the wiring and 32A breaker with a properly sized supply fusing arrangement or breaker, it will need to be around 60A, since it wouldn't be good practice (or code-passable) to put two fuses or breakers of the same size in series. That would seem that the wiring would then be too small. What is your suggestion?
