Does code allow the use of an unused subpanel as a junction box?
Breakers would be removed and I assume both the ground and neutral bus bars would also be removed. In this case there was a slot in the front cover for two breaker spaces which would also have to be covered.
I suspect this is wrong since it is not listed for such a use.
