T Teaspoon Senior Member Location Camden,Tn. Jul 22, 2016 #1 Is it permissible to use UF wire for 120 volt twist lock receptacle for pool pump ? (Above Ground Pool)
T Teaspoon Senior Member Location Camden,Tn. Jul 22, 2016 #2 Teaspoon said: Is it permissible to use UF wire for 120 volt twist lock receptacle for pool pump ? (Above Ground Pool) Click to expand... . Ok I found The Article 680.21(1)
