Keep in mind:
5-15kV breakers and 600V ANSI Air Frame breakers are designed so they can be re-conditioned or completely disassembled and rebuilt. There are a number of companies as well as the OEM that will rebuild these breakers.
Molded Case breakers are not designed to be reconditioned or "re-built". The cases are epoxy sealed and designed to be tamper-proof. There there are no parts or repair bulletins made available by the OEM's for anyone to refer to to ensure the proper parts are replaced and the interior mechanical tolerances are maintained.
I have personally been involved in situations where "NIB" breakers have been purchased from companies dealing in used and surplus breakers. I have seen doctored labels, breakers that showed they had been exposed to excessive heating on the terminals, breakers that have been exposed to water due to a fire or flooding. Granted some breakers may come from inventory from a bankruptcy or closing, however as these units are all puchased 2nd hand there is no guarantee what the breakers have been exposed to.
My first recommendation is that the breaker is puchased through an authorized OEM channel. If that is not feasible due to the availability of an older breaker, I would recommend that you obtain the services of a testing firm that can perform tests per NETA standards on any "used" breaker.
Most customers are not apt to accept "used" breakers when they are still available from the OEM, and will be highly upset if they find out after the fact.
Also you need to keep in mind the OEM's warranty. Most OEM's warranties state that if devices are installed that are purchased outside the proper channel, it voids the warranty on the overall equipment and if there is any collateral damage to the equipment due to the failure of the breaker you are left purchasing a new piece of equipment. Typically if a failure of a breaker damages the panel, switchboard/gear,etc... the manufacturer typically will work with you to cover the cost of repairing the equipment.
The best question is how much liability are you willing to assume.
