allenwayne said:
You walk up a curved staircase that leads to a loft type area that leads to the bedrooms. To access the bedrooms you have to walk through this area there is no choice so if that doesn`t constitute a walk/hallway what does?
Based on this description, I would definitely call that a hallway. IMO the Inspector was wrong to treat it any other way.
But since you hijacked this thread from its originator, I think I'll try to hijack it from you. :wink:
iwire said:
Yes it's required and IMO the lead man should have brought this up before walls are closed.
Not to pick on you, Bob, but why it is required? Specifically, why would a railing require a receptacle? Everyone seems to believe that, for example, if a living room has a 6 foot railing dividing it into two areas, there must be a receptacle (probably in the floor) next to that railing. Why?
Please take a look at 210.52(A)(2)(3), and tell me what the word "afforded" means? I asked this once before in another thread, and nobody responded. "The space afforded by . . . railings." What the heck is "afforded by"? Look up the word "afforded" or just "afford," and you will see nothing that is even close to applying in this context. If the code said, "the space created by," or "the space established by," or "the space adjacent to," then it would have made sense. IMO the best way to word it would be "the space occupied by." But "afforded by"? :? :?:
If I build my own house, and if I put a railing in the LR , and if I don't put receptacles near the railing, and if the Inspector red tags it, I am going to say that 210.52(A)(2)(3) does not apply, because I cannot "afford" any more receptacles. :wink: 8) :lol:
