Hi, I have a question about 12/4 (12/2/2) romex. I have the type that has a black,white,red and white with red stripe. Can the white with a red stripe be used as a neutral? I would like to use the black and white to feed a GFCI outlet and then use the red and white/w red stripe on the load side of the GFCI to back feed another outlet. The feed goes to an outlet on the ceiling of a garage. I would run the 12/4 from this outlet to an outlet on the wall to get my GFCI protection for the ceiling outlet and make it GFCI and readily accessible. Is this code compliant? Thanks
