I notice that NEC 2011 has two temperature correction factor tables 310.15(B)(2)(A) and 310.15(B)(2)(B) based on 30deg C and 40dec C. Most of the designs I have seen use the 30deg C table for de-rating both 75deg and 90deg rated conductors. Is the 30deg table typically used for correcting cable ampacity for ambient temperatures? When is the 40deg table used? Can someone explain the difference between the two?
