If I recall there is a section in the NEC stating that for any breaker with an ampacity less than 100A you must use the 60deg C rating for determining cable ampacity for cables I believe up to size #1.
Is this always the case, that you must use the 60deg column or if you know that the breaker terminals are rated for 75deg C then can you use the 75deg rating?
