Todd Gaudet
- Roseville, ca
[h=2][/h]
I have a circuit single breaker inside a panel that feeds a piece of equipment. I would like to install a power distribution terminal block in the panel and have the 480 vac feed the existing breaker and feed another piece of equipment at the location. The 480 vac will come off the terminal block and out the panel to feed the new piece of equipment. Is this ok to do. Also is it ok to pigtail in a breaker panel. Only has one breaker in the panel and is a 20 amp breaker. I would be bypassing the 20 amp breaker and coming off the main breaker which is 60 amps. Any information would be much appreciated.
Thanks,
Todd
Thanks,
Todd
