A guy at work was using a no-dog, and putting a level on the hand bender handle. The work is all exposed EMT, he says it helps eliminate dog in the pipe. I've never seen anyone do this. Any opinions? Thank you for your help.
I would never use a no dog on a hand bender. If I couldn't do it by eye it would be time for some glasses.
i'm assuming he was using a level on the bender handle in addition to the no dog...
honestly, if you can't tell if a three foot long bender handle is plumb or not, you
really need to stop trying to bend conduit.
Yes a level on the handle also.
After enough glasses, you may need the no-dog just to carry the pipe.![]()
When bending handle up, a 0/30/45/90 level on the handle could help someone make more accurate angle bends. Some GB benders have a bubble vial built into the shoe, but it's only good for handle straight up 30° bends (some of their older shoes were 45°). On occasion, I've used a protractor for odd angle bends.Yes a level on the handle also.
It only works when working surface is level, some people almost always have that, others do not.When bending handle up, a 0/30/45/90 level on the handle could help someone make more accurate angle bends. Some GB benders have a bubble vial built into the shoe, but it's only good for handle straight up 30° bends (some of their older shoes were 45°). On occasion, I've used a protractor for odd angle bends.
Ok maybe I'm too old...what is a no dog? I've used hand benders usually no dog leg On my bends but if there is use steps or the vice and bender handle to fix.
