OK then, where is your grounding conductor when the diode blows out during a fault?danickstr said:would it be a bad idea to use a , say 35 amp rated diode on a grounding conductor as a means to create a ground loop resistant 15amp circuit leg?
I have thought about doing this to fix complex wiring hum issues and did not know if it would be a reliable gound path.
mdshunk said:Maybe try to figure out where the current's coming from, rather than some silly (potentially unsafe) arrangement to block it?
danickstr said:But i am open to thoughts to continue. Isolation transformer is a possibility.
danickstr said:The usual alternative in recording studios is the ubiquitous ground lifter device sold at the supermarket.
plate said:I am not familiar with the ground lifter terminology, can you provide the formal name or link? Thanks
LarryFine said:
