Hey everyone, I ordered a transformer that said it was a 240d-208d transformer, and without seeing it said it was an autotransformer, I assumed it was isolation because of it being delta-delta. I’m wondering if I can use it to buck the voltage for my delta load from the high leg delta line feed. Would I just connect H 1, 2, 3 and x1, 2, 3 and ignore the common X0/H0 neutral point? Ground line and load to the ground bar and call it a day? I’m guessing this could be problematic if there is any significant control circuit current causing imbalance. I’m going to call the manufacturer tomorrow, but wanted to see if anyone has dealt with this before. The nameplate clearly says 240wye to 208 wye with a star configuration diagram.
The load is a CNC lathe (Doosan Lynx if that matters)
