Hello,
I'm new to this forum, and I'm not an electrician.
I know enough to ask good questions but to listen to competent advice!
Hoping someone might help me with a new project -
In my previous lumber & millwork company we used a lot of ITE XL buss duct in the factory.
It is 600 VT rated and has 600 AMP capacity.
We used 230 LF of 10' bussway and 30 plugs ranging from 30 to 200 amps.
When I closed the business a few years ago and sold my building,
We removed the buss duct and plugs for future use.
It has been in dry storage and is in good condition.
Back then I thought I would start another smaller millwork business, but times have changed...
Now I am planning to build a small "retirement" shop for myself.
I would like to use just 60 LF of the buss-way, two of the end connector boxes and several plugs.
Would likely not be running more than 200 Amps through it.
It would be on 240 VT 3 PH, not 480 VT.
Power would either come from a phase converter or a small 3 PH generator.
My new shop is only 26x40 and I figured on mounting two 30' runs, each one mounted on opposite side walls up toward the ceiling.
Then I would have flexible hookups to locate my smaller 3 PH machines anywhere along the length of the building.
My local commercial electrician thinks it is overkill, but I'm not sure he knows enough about my project, yet.
If I use my buss duct, I would still have a good bit of surplus hardware to sell, too.
I am located in western MD.
I appreciate any advice you may have.
Thank you for your time,
Barry
Barry
