Using ceiling grid as support of fixtures
grainger
Can a ceiling grid be used as means of support for 2'X2' lay-ins? The ceiling grid is not rivited to side angle supports.
ryan_618
Re: Using ceiling grid as support of fixtures
Where are you located? It depends on the seismic design category you are located in (2000 IBC 1621.2.5). Odds are that you will need to have 2 wires supporting it.
russ
Burbank IL
410.16(C) explains the ceiling requirements as far as the NEC is concerned.
