RustyShackleford
- NC
- electrical engineer
Is it acceptable to remove the insulated conductors from NM and use them in conduit (where one would normally use THHN/THWN or XHHW) ?
Sort of nit -picky, but IMO it's not just that they are not marked, it's that they are not an NEC conductor. If you look at the standards for NM, there is a whole bunch of messy language that doesn't really say the inners are thhn.
They are an NEC recognized conductor. See 334.112.
It's just they're not required to be marked individually.
I have *very* rarely seen marked conductors inside actual Romex branded NM-B, but not in years, perhaps before General Cable was bought by Southwire. I recall reading from an unverifiable source (more forum chatter) that marked conductors would occasionally be used in NM if the factory had run low/out of unmarked thhn, implying that it was simply an expedient and not a specification. But again, that part is all just innuendo.
But whether they're marked or not, they're required to be an NEC-recognized conductor/insulation.
Tough pull.You can use the conduit as a sleeve for NM though.
No, UF in PVC is a tough pull. :roll:Tough pull.
334.112 Insulation. The insulated power conductors shall
be one of the types listed in Table 310.13(A) that are suitable
for branch-circuit wiring or one that is identified for
use in these cables.
This?
Or this:
[/COLOR]
