Using disconnect as a raceway
Ckreider12
New member
Manheim,pa,usa
We are Feeding a pump from a mcc bucket with a vfd. The spec calls for there the be vfd cable from the mcc bucket to the pump disconnect. It also calls for the control wires for a start/stop push button (which is to be located beside the disconnect) to be ran in the same conduit. My question is can I run the control wires through the disconnect to the start/stop push button according to 312.8?
