Using Flex Metal Conduit as a raceway an not as an Equipment Grounding Conductor.
Will Wire
California: NEC 2020
Electrical Contractor
Is it code compliant to use Flexible Metal Conduit Type FMC as a raceway longer than 6 feet, provided an equipment grounding conductor is included with the circuit wires. I want to bring it across an attic 15 feet from an LB to a box in a kitchen soffit.
My understanding is this is compliant because I would not be using the Flex as the equipment grounding conductor.
Thank you.
