syd
New member
- New Hampshire
Finishing up a rear-dormer addition that is going into it's 10th year (and has been dormant for the past eight years).
So. . . I had a family member do a lot of the wiring.
As I start working on the project again I have discovered that he installed junction boxes in the basement and then ran multiple lines to the second floor from those junction boxes.
One box has power in and then multiple lines out to individual outlets in multiple rooms.
Another box has power in and then separate runs for each outlet and fixture in the bathroom.
I have no idea why it was done this way - in the end it used so much more copper than it would have used going from outlet to outlet.
While (I believe) that as long as the junction boxes are the right size they comply with code - it's also my understanding that junction boxes are less than desirable.
I have done a lot of research and can't seem to find anything on why junction boxes are not preferred.
I'd appreciate any insight into the matter.
Anyone have an opinion on distributing power in this way?
Is this a problem?
Thanks!
Is this a problem?
Thanks!
