Bluewyvern
- Mechanicsville, VA
I have some 5kv cable that I want to use in a 480V application. Can I take credit for the higher current rating for the cable in the low voltage application? For example, the code says for <2000 volt cable a 750 MCM 90 degree triplex cable in conduit ampacity is 535 amps. A 5kv triplex cable rated at 90 degrees in conduit ampacity is 600 amps.
