I've seen several installations where the electrical contractor has decided to use panel skirts on the bottom of the wall mount panels in lieu of providing conduit risers into the panel. There have been several instances where the bottom of the panel was removed and the panel mounted directly to the concrete slab. The slab penetrations have been plastic and the ones that I've seen with metal were all bonded together with bond bushings and then bonded to the panel can.
I was wondering if this could be an issue with the Arc Flash rating or possibly a code issue due to the fact there is no bottom to the panel.
