Designer69
we need to use the same fan failure alarm contact to provide two different alarms to two different annunciator circuits. (see attached)
originally I was going to just connect both different annunciator sources to the same contact then I realized that this could be a big mistake as 2 voltage sources are now connected in parallel.
is there a better way to do this? a common workaround?
There are no other available contacts for this fan failure alarm that we know of, so if new additional components is what we need, so be it.
Thank You
Thank You
