ampdsnoborder112
New member
According to NEC article 200.7 (C)(2) it mentions that where there is a cable assembly that contains an insulated conductor for single-pole, 3-way, or 4-way switch loops, the white wire can be used for the supply to the switch but not as the return conductor from the switch to the switched outlet. What is not mentioned is whether or not it is permissable to use the white wire as a traveler? As an example, when the feed is in the fixture box and a 3-wire is run from the fixture box to each 3-way switch, which is a common installation technique in older homes in this location. I'm an electrical student, and this is a point of discussion in the class. Any help is appreciated. Thanks!
