What kind of "board". What UL standard?Hello,
I would like to if there are restrictions in the UL regulations on using white wire (or other colors) for wiring I/Os (24VDC, 4-20 mA)?
Thanks a lot,
Gonen
Thanks Bob
It's an electrical & control board, 460 & 110V feed, Class1,Div2 (equipped with Type Z purging unit).
My problem is that my board manufacturer encountered shortage of grey wires for wiring the IO, from the controller to the wiring terminals...
Therefore, I would like to know if he can replace the grey wires with white ones.
It's only for wiring the 24VDC, 4-20 mA signals.
All the transmitters (110V) are properly wired.
Gonen
Only thing white should be for is AC neutrals. The grey DC wires should be blue per UL508A. Your panel would not get listed
as wired. As pointed out the whites may cause some confusion in the field. But unless you plan on having it listed it really doesn't
matter and in fact we have some older panels at work that use white for all kinds of stuff. I would advise using a different color.
OP lists Israel as location... so it really comes down to what standards are in effect where the installation is located.It cannot be listed under UL508a....
Most 4-20mA field wiring is black and white twisted pair. I fail to see how it would be any more confusing than connecting black and white to blue and white/blue.... As pointed out the whites may cause some confusion in the field. ...
From the OP.OP lists Israel as location... so it really comes down to what standards are in effect where the installation is located.
Duly noted...From the OP.
Since he specifically asked about UL requirements, I tried to respond to his actual question and not speculate about what standard it "should" be built to.
For UL508a industrial control panels:
4-20mA signals are not normally "wire". They are normally shielded cables. I don't know that this is required though. I would have to look. The color coding of conductors within cables is allowed to be different than for single conductors, but without looking I don't recall what differences are allowed.
DC single conductors are required to be blue for ungrounded conductors and white with a blue stripe for grounded conductors.
What if you have ungrounded DC? Both can't be blue....or you couldn't identify polarity. Hmmmmm.....
