I recently was called out to replace a transformer at a machine rental shop. I wrote down the model number and got a replacement transformer (75 KVA 480 volt primary 240 volt delta/delta). After hooking it all up and turning it on everything seemed fine. I then went outside to look at a separate project. I then noticed there were 3 utility transformers on the pole and it appeared to be a wye system. The question I have is, is the new delta transformer going to burn up if it is indeed connected to a wye?
