On utility secondary services are C/T cabinets usually grounded? From the C/T cabinet drawing from the utility It indicated three phases and neutral from the utility xfmr. (not bonded N-G until it lands in the switchboard inside the building however the C/T is on the exterior of the bldg between the xfmr, and switchboard? Does this mean that the conductors from the xfmr to main switch are "ungrounded" since not N-G connection is made in the xfmr, and only 4-conductors are installed from the xfmr to the main switch?
