kingpb
- SE USA as far as you can go
- Engineer, Registered
I keep seeing on drawings 3PH, 4W for the utility connection. But, MV (or HV) don't have a neutral conductor, which would be part of a 3PH, 4W system.
Wouldn't this correctly be 3PH 3W +ground?
Secondary Q; the "ground" or earthed conductor at the service entrance from utility just comes from driving a ground rod. I have never seen an actual ground conductor run with the 3 phase conductors.
