Typical utility demand meter (208V 3Ph using current transformers):
Is the measured demand instantaneous? (as opposed to averaged over half an hour or whatever)
If the load is not balanced, does it read the highest leg?
Usually KW or KVA? (I’m not sure how this would shake out off the top of my head, see please chime in if this is a factor. The email from the utility said KW.)
The reason I ask: Usually when you see the highest demand it is much less than the connected load. I just received a demand, from the utility, that I don’t think could be reached if everything in the building were on at once.
(This case is a small town highway garage with a lot of non-continuous loads like air compressor, truck lift, door openers. (the service size is 225A, the demand they gave is 89.6KW.)
