jtester
- Las Cruces N.M.
Our local utility just threw a new twist in designing electric services. They rejected a 200 amp service with a 200 amp meter and a panel having a 200 amp main breaker serving as a service disconnect because the panel board bus is rated for 225 amps. They believe someone will change out the 200 amp main breaker to a 225 amp breaker and overload their meter. They have a similar rule for their 320 amp meter, but that is really messy since panel busses are rated 400 amps, and fusible disconnects in the 400 amp class can accept up to 400 amp fuses. I don't know of any that stop at 300 amps.
I have always believed that utility meters can withstand as much as 100% overload, but I can't find any good information on that subject. I hope to discuss this issue with the utility, but would like to know if their overcurrent protection efforts are appropriate and even common.
Thanks in advance for any information or opinions you might have.
Jim T
Jim T
