David Christian
- Fremont, CA, USA
Hi Guys,
When I read PG&E Greenbook, I noticed that there are two tables of utility Pad mounted transformers. One is called " Dimensions and Codes for style IIA,IIB,IIC,IIF and IIH Transformer Pads". another one is called " Dimensions and Codes for style IID,IIE and IIG Transformer Pads".
Is there any difference between IIF transformer pad and IIE transformer pad?
For example, if I have one lab project. Based on my load calculation, I need to choose 2500kVA utility pad mounted transformer. If I choose IIF transformer pad, the dimension is 120"x115". If I choose IIE transformer, the dimension is 106"x90".
Thanks for all the suggestions.
Best,
David
Best,
David
