Utility required 59N relay, requiring Yg-Yg PT connection?
Andrew445
Inactive, Email Never Verified
I am working on a grid-tied project, where the utility is requiring 59N protection at the secondary of the GSU transformer. The inverter output connection is delta, stepping up to grounded-wye.
It is my understanding that the 59N relay connection is typically open delta. The relay monitors across the open delta. The utility is requiring the PT connection to be grounded-wye/grounded-wye. Can this be accomplished?
Thank you for your help!
I can't say much, except that I think most likely you'd have no problem connecting a delta inverter to a grounded-wye system. Consult the inverter manufacturer to be sure.
I believe that is true but the opposite is not.
Thanks guys.
I think one main problem is that introducing a ground with the PT messes with the inverter. The second is that most common 59N relays use the broken delta connection (Basler BE1 for example).
I think we will need to propose something alternate to the utility.
Thanks guys.
The Basler BE1 59N manual shows three different connections, one is a broken delta for use on ungrounded systems on page 4-10. Basler could probably recommend a connection scheme if contacted. These relays existed long before PV so the manuals only show the traditional uses.
