FaradayFF
- California
Hi All,
This question may not be appropriate in this forum, just wanted to ask how are the utility service conductors are protected. Say a set of overhead service conductors feed a customer. I suppose the overload protection can be provided at the mains breaker of the panel/meter supplied by these conductors.
How about protecting against the short circuit anywhere along the length of the service conductors before they enter the customers disconnect device. I haven't seen protective devices installed immediately downstream of the OH transformer, is the typical assumption by utility here is that we're dealing with a short run to the customer's disconnecting means, and in case of a fault, the fuses on the primary side of the utility OH transformer would clear the fault?
Thanks,
EE
Thanks,
EE
