Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
Forgive me I know this has been discussed before. But I’m getting requests about this more and more.
I don’t work with solar much, so my understanding is that with battery backup, either the entire house is run through the batteries (small system), or the system transfers over to battery through an ATS on utility failure.
My thought on adding a generator would be either coordinated transfer, where batteries would kick on first, then gen power would come on when batteries are depleted. That one seems more complicated.
Second idea is to have the generator come on when battery voltage drops to a predetermined level, and have a smaller generator that just charges the batteries.
Obviously, this depends a lot on the system already in place, like how much battery storage, whether the batteries run the entire unit or just critical loads, etc.
I know on the Generac controller, you can adjust the utility drop out and cut in voltages. I wonder if it would work to adjust those voltage level to correspond to a level of battery depletion, using line voltage through an inverter of course, to make the generator kick on to charge the batteries.
If anyone here has built out a system like this, I’d love to pick y’all’s brain about it.
