The local utility company is going to install 500KVA transformer, secondary voltage is 480/277V, can I connect one set of 500kcmil conductors to feed a 400A service rated panel with main breaker to the transformer lugs, and another set of conductors 3/0 conductors to the utility transformer secondary lugs to feed a 200A panel with main breaker? Length of each set of conductors is 20', transformer will be a pad mount, and the two panels will be 3R rated and installed outdoors, next to the transformer.
