Utility / Transformer Problem?
davedottcom
A house I wired this year has been having strange problems!
First Call Back: (1 week after C.O.)
1) Both GFCI outlets on the kitchen counter were "shot".
And at the same time...
2) A 20 Amp GFCI breaker was also "Shot"
Second Call Back: (3 months later- Today!)
3) The 12 V underwater lt bulb was "Shot"
and at the same time...
4) ALL 3 60 watt lt bulbs in the garage blew out at the exact same time!!!
Homeowner said she turned on the lights...they came on for a second...then Poof!
I've checked the voltages and service connections everywhere. Everything looks fine. I told them to have FPL check the Transformer and overhead connections for a possible loose nuetral.
Any other suggestions or thoughts on this one?
Thanks, Dave
Re: Utility / Transformer Problem?
No, definitely not. I forgot to mention that. This IS the lightning capital of the world but both occuraces have happened during very calm weather. I remember considering that the first time, and we all (myself and the homeowners) agreed there had been no lightning storms in the area...and I know there has not been any storms the last few days.
I agree it is a utility problem or a lightning strike as Peter mentioned. I doubt though it is a lose neutral. If it was a neutral loose they would lose power through out the whole house. It sounds as a surge. How good is your ground. Have you done a fall of potential test? Tough problem good luck.
No, and to be honest I've never heard of one. Would this be a test the Utility Co. would do if requested?
AS for the ground, I didn't take an ohm reading but I used #4 solid copper to 2 5/8" Galvanized ground rods like I always do. Everything is intact and I used Noalox where it terminates.
It sounds like you have high potential surges in any case.
Have you tried installing a whole-house surge protector?
Surge Protecter? Yes, just today!
A Square D SDSA1175 Series 001
The service has a GE Meter-Main Comb. so I installed the S.P. on a 2 pole 40 amp right in the Meter-Main.
Showed the owner the little green light and told him to check it everyday and call me if it goes out!
If you don't believe it was lightning have you ask your customer's neighbors if they are experiencing any problems?
I am 99.99% sure it was not lightning!
(Always a chance!)
The house has it's own (brand new) transformer but I'll ask the neighbors tomorrow. Good Idea.
Well, I knocked on doors today! Only 2 neighbors were home:
First neighbor said they have had no problems.
Second neighbor said their pool pump stopped working 2 days ago!!! I asked to look at it...it hummed a little...sounded like it was seized, but the thing looked about 10 years old so???
I called FPL and their sending out a crew to check the Transormer / connections.
The surge protector I installed yesterday was still working according to the little green light!
Dave
Only thought i have is are there any multi wire branch circuits.Open or loose connection there would fry gfci.3 bulbs same instand says unbalanced voltage.Check neutral from transformer all the way to them 3 lamps.Each and every connection and tighten all panel neutrals.Let us know outcome.
