We are working on a project and are exploring different options for the customer. The facility currently has a 120/208, 3? 1200 amp service with a 300KW automatic generator between the transformer and main service disconnect. There current peak demand is 233 amps.
The customer is adding approx. 1200-1350 amps of new loads. The utility company?s transformer has built-in CT's with a meter mounted next to the transformer. The POCO stated the transformer and CT's can handle an additional 1200 amps.
The only way we have come up with using the existing transformer without changing the existing gear would be to install a new 2000 amp main service disconnect between the transformer and existing gear; then feed the existing service and a new 800 amp panel. Approx. 800 amps of the new load will be fed from the existing gear.
Is it possible to do it another way?
Please see attached one-line.
