utilzation equipment? per 2008 code
rbalex
Mission Viejo, CA
Professional Electrical Engineer
The switch does not actually "use" the electricity - it contols it. In its most basic concept, utilization equipment converts electricity into another form, like a stove converts electricity into heat or a motor into electromechanical.
Edit add: So now what's your answer? ;)
rbalex
Mission Viejo, CA
Now I am thinking thermal overload? Yes :?
Better and I could make the case for it if I had to since it "uses" the elctricity to make heat, but its real purpose is still control. There's an even better answer that I suspect the question was looking for.
jim dungar
Wisconsin
PE (Retired) - Power Systems
I think Bob is hinting at a definition of 'utilization' being 'uses'.
Why, are you making your choices?
PEDRO ESCOVILLA
south texas
garbage disposal if it's a test question. even if it's not, it will "utilize" electricity, it is "eguipment", a fridge, freezer, toaster copier machine ad nauseum, as been said before, see definitions, article 100
rbalex
Mission Viejo, CA
Indeeed garbage disposal is the "correct" answer - but not because it is equipment; so were all the other items listed. See the definition of equipment in Art 100.
