Hey, fellas. I have a situation where a customer wants to add UV-C lights inside some existing 3ph 480V RTUs. The units are fed through their base, so the power comes up directly into the unit through the curb. The lights would be minimal load (less than 1 amp at 277V). This is negligible compared to the RTU circuit and could be easily done with a fused wire tapped from one phase in the RTU.
However, the unit does not account for this tiny current on its label (Minimum Circuit Ampacity or Branch Circuit Selection Current). Technically, this little change would invalidate the engineered label. It is not practical to tap the 3ph RTU circuit before it hits the unit due to power going through the base into the unit- the circuit is not accessible on the roof until it enters the RTU.
I do not see anything in Section 440 that explicitly addresses this situation to allow/disallow tapping the circuit within the unit to add the UV-C. I understand there could be warranty concerns if what I add fails, like a burned connection or something, but I am wondering about a code violation.
Does anyone see a NEC violation by tapping the RTU circuit within the unit?
