Va into watts
gar
Ann Arbor, Michigan
EE
111222-2030 EST
Tebow:
What is a VA?
What is a watt?
How are these related to each other in a DC circuit?
What is different in an AC circuit when the load is a pure resistance?
What about other AC loads?
T
T.M.Haja Sahib
Guest
111222-2030 EST
Tebow:
What is a VA?
What is a watt?
What is a VA?
VA=VOLTAGE X CURRENT
What is a watt?
WATT=VOLTAGE X CURRENTXPOWER FACTOR
VA=WATT
VA=WATT
Note:-The above equations are for two wire circuits only.
gar
Ann Arbor, Michigan
EE
111223-0720 EST
TM:
The questions were directed Tebow to get the thinking process started.
Now I want Tebow to give some other definition and discussion on what is a watt.
T
T.M.Haja Sahib
Guest
gar:
Even trying to explain which side to work out first in the equations of my post is a good exercise for him.
