philhurtgen
- Indiana
- Apprentice Electrician
Hey guys,
Got a strange situation here, and I'd appreciate y'all's insight! My company is currently installing a vanity light and lighted mirror for a customer, and the original intent was to have both fixtures on a single led dimmer switch, in order that you could dim both fixtures simultaneously. However, as it turns out, the lighted mirror did not react this way in practice, and we also discovered that the lighted mirror had a built-in dimmer function via a touch-sensitive button. So, when dimming down the vanity, the lighted mirror had no change in brightness-it did, however, produce a slightly audible hum when not set at the same relative brightness as the vanity; adjusting the lighted mirror to the same brightness as the vanity would quickly resolve the hum.
Our question in all this is simply if this is perfectly safe, or if the dimmer switch could somehow adversely affect or "harm" the lighted mirror. It seemed strange that the brightness of the mirror wasn't affected by the dimmer, even though both it and the vanity were on that same switch.
Always appreciate the answers I get on this forum.
