WMagill66
- Sterling, VA
I need some advice on selecting a VFD for my application. I'm building a "Test Rig" to compare 2 different UPS systems. I want to be able to adjust the input frequency (and voltage) of the UPS's. My input to the VFD (or other device) is 120VAC 60Hz and I need a 120V output (1HP or 8 Amps). I want to be able to adjust the frequency from approx. 55Hz to 65Hz while monitoring the UPS outputs with a scope. I also want to put a non-linear load on the UPS outputs. VFD's with single phase output are not standard. Can you give me some direction for the best product? Am I thinking along the right path with a VFD?
Thank you very much.
Walter
Walter
